MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | MAM Assets : Creating a New Folder
You can create new folders in the Interplay MAM Workspace. Your ability to create a new folder depends on Interplay MAM rules. For example, the credentials you use to sign in to the Interplay MAM database must allow creation of folders.
For more information, see the Interplay | MAM Desktop User’s Guide or Interplay | MAM User Manager User’s Guide.
To create a new folder in the Interplay MAM Workspace:
1. In the Assets tab, select a folder.
*The new folder is added as sibling or subfolder depending on the control you use.
2. Do one of the following:
*To create a sibling of the selected folder, click the Pane Menu button and select Create Folder.
*To create a subfolder within the selected folder, right-click the folder and select Create Folder.
A new folder is created with the name New.Folder. If there is already a folder named New.Folder, .01 is appended to the folder name, and incremented for each unnamed new folder (New.Folder.02, and so on).
3. Rename the folder. See Renaming a Folder.
