MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | Production Assets : Creating a New Folder
You can create a new folder in the Interplay Production database. Your ability to create a new folder depends on Interplay Production rules. For example, the credentials you use to sign in to the Interplay Production database must allow creation of folders.
For more information, see the Interplay | Access User’s Guide or your Interplay Production administrator.
To create a new folder in the Interplay Production database:
1. In the Assets tab, select a folder.
*The new folder is added as sibling or subfolder depending on the control you use.
2. Do one of the following:
*To create a sibling of the selected folder, click the Pane Menu button and select Create Folder.
*To create a subfolder within the selected folder, right-click the folder and select Create Folder.
A new folder is created with the name New.Folder. If there is already a folder named New.Folder, .01 is appended to the folder name, and incremented for each unnamed new folder (New.Folder.02, and so on).
3. Do one of the following to rename the folder:
*Select the folder, click the name of the folder, and type the new name.
*Select the folder, press F2 (Windows) or Enter (Macintosh), and type the new name.
*In releases prior to MediaCentral UX v2.9, the only way to create a subfolder for Interplay Production assets was by navigating into a folder and creating a sibling folder.
