Duplicating Assets
Duplicating an asset in the Interplay Production database creates a new asset, with new metadata (MobID). You can duplicate master clips, subclips, audio-only clips, and sequences.
To duplicate an asset, do one of the following:
Right-click the asset you want to duplicate and select Duplicate.
Select the asset you want to duplicate, click the Pane Menu button, and select Duplicate.
A new asset is created in the same folder as the original asset, with the extension .duplicate. The name is highlighted in edit mode so that you can easily rename it.
