MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | Production Assets : Moving or Copying Folders
You can move or copy folders in the Interplay Production database by using the Cut, Copy, and Paste commands.
To move a folder to another folder:
1. Select one or more folders.
2. Right-click and select Cut.
3. Select the folder into which you want to move the folder, right-click, and select Paste.
The Move Folder message box opens.
4. Do one of the following:
*Click Yes to move the folder including its contents.
*Click No to keep the folder including its contents in its original location.
If you selected both a folder and individual assets, only the individual assets are moved.
*Click the X button to cancel the move operation.
To copy a folder to another folder:
2. Right-click and select Copy.
3. Select the folder into which you want to copy the folder, right-click, and select Paste.
The Copy Folder message box opens.
*Click Yes to copy the folder including its contents.
If you selected both a folder and individual assets, only the individual assets are copied.
*Click the X button to cancel the copy operation.
