Exporting a Basic Sequence (Interplay | MAM)
When you are finished editing a sequence, you can export it using a MAM Export process. To do so, the sequence does not necessarily have to be open in the Sequence pane.
Your ability to create and initiate MAM Export processes depends on Interplay MAM user privileges and rules. For example, the credentials you use to sign in to the Interplay MAM database must allow creation of MAM Export processes. Beyond that, the MAM Export profile must be available and configured in Interplay MAM.
To export an Interplay MAM basic sequence:
1. Do one of the following:
Open a basic sequence in the Media pane.
In the Assets pane, navigate to the desired folder and select the basic sequence.
In the Search pane, conduct a search and select the basic sequence in the results list.
2. Do one of the following:
Click the Pane Menu button and select Actions.
(Assets and Search pane only) Right-click and select Actions.
3. (Option) Select the MAM system on which the Export process is to be created.
4. Select MAM Export > (target-name), such as “All destinations” or “Export to Standard.”
The MAM Export process dialog box opens. The following illustration shows MAM Export process dialog box for “All destinations.”
5. Provide the required information and click OK.
If the sequence is open in the Sequence pane and has unsaved changes, a dialog box is displayed.
- Click Yes to save the changes and export the changed sequence.
- Click No to keep but not save the changes and to export the unchanged sequence.
- Click Cancel to keep but not save the changes and cancel the export.
For information on monitoring the process, see
Monitoring Processes in the Progress Pane.
