MediaCentral | UX User’s Guide : Using the Sequence Pane : Viewing Sequence Information
You can view the sequence name, format, and other details about the sequence loaded in the Sequence pane.
To view sequence information:
*Move the mouse pointer over the Sequence pane’s tab.
The following table describes the information you can view for Interplay Production sequences.
Item
Description
Name
The asset name as listed in the Interplay Production database.
Format
30i NTSC
25i PAL, 25p PAL
720p/25, 720p/29.97, 720p/50, 720p/59.94
1080i/59.94, 1080i/50
1080p/25, 1080p/29.97
Aspect ratio
4:3
16:9
Raster Dimensions:
720x486
720x592
1280x720
1920x1080
The following table describes the information you can viewfor Interplay MAM basic sequences.
Item
Description
Name
The basic sequence name as listed in the Interplay MAM database.
Type
Type of sequence: Video or Audio. Defined when you create the sequence and cannot be changed.
Frame Rate
Sample Rate
Frame rate of a video sequence or sample rate of an audio sequence. Defined when you create the sequence.
Mixed Frame Rate
Indicates if you can add clips with differing frame rates to the sequence: allowed or prohibited. Allowed by default, but can be prohibited by configuration in Interplay MAM.
Rights
Usage right of the sequence:
Free for use
Not evaluated so far
Parts need to be licensed
Contains restricted parts
The usage right for the entire sequence is determined by the most restrictive usage right for a segment in the sequence.
Duration
Calculated automatically when you add or remove segments, or change the segment length.
No of Segments
Calculated automatically when you add or remove segments.
Note
Is shown when you open a read-only basic sequence; informs you why the sequence is read-only: due to Interplay MAM access rules or because it represents an external sequence.
