Displaying the Sequence Pane
The Sequence pane is displayed in the default Cut, Log, and Story layouts. It is displayed with a horizontal timeline in the Cut and Log layouts, and with a vertical timeline in the Story layout. You can change the orientation if you prefer (see
Selecting a Horizontal or Vertical Timeline).
To display the Sequence pane:
Select Panes > Sequence.
The Sequence pane opens in the mode and orientation in which it was set when you signed out of the application.
