MediaCentral | UX User’s Guide : Building a Script : Copying and Sending iNEWS Links
You can copy and send links to stories, queues, iNEWS folders, iNEWS facets, and iNEWS projects. These links are in URL format and can be shared through e-mail, wikis, documents, or chat messages. The links are valid as long as the item exists in the iNEWS database.
When you click an iNEWS link or paste it into the address bar of a supported browser, MediaCentral UX opens with the correct layout and asset selection. If you are not signed in, the sign-in screen is displayed. After signing in, the link target is displayed.
You can select Copy Link or Copy Container Link. Copy Link creates a link to the selected item, and Copy Container Link creates a link to the item that holds the selected item.
To create a URL for an iNEWS link from the Asset pane, do one of the following:
*In an iNEWS list, right-click an item and select Copy Link.
*In an iNEWS list, select an item, click the Pane Menu button, and select Copy Link or Copy Container Link.
To create a URL for an iNEWS link from the Queue/Story pane or the Project/Story pane, do one of the following:
*Right-click an item and select Copy Link.
*Select an item, click the Pane Menu button, and select Copy Link or Copy Container Link.
To create a URL for an iNEWS project link from the Launch pane, do one of the following:
*Select an item, click the Pane Menu button, and select Copy Link.
In all cases, a popup dialog box opens with a URL that is already selected for copying. Press Ctrl+C (Windows) or Command+C (Macintosh) to copy the link, then use Ctrl+V (Windows) or Command+V (Macintosh) to paste the link.
