Inserting MOS Placeholders
You can create a placeholder item for a third-party MOS device in an iNEWS story, in either the story form or as a story’s production cue. To add it to the story form, the story form must be capable of including MOS information.
The iNEWS server must be running iNEWS v4.0.3 or later.
To insert a MOS object placeholder:
1. Position your cursor in one of the following places:
- In a segment in the Story editor.
- In any field in the Story form.
2. Click the Pane Menu button and select Insert Placeholder.
The Create MOS Object Placeholder dialog box opens.
3. Select a device name and enter a title. Optionally, enter a description.
4. Press OK.
The new MOS object placeholder appears as a production cue in the Story editor and the Cue List, or in the MOS-Title field.
The MOS device user can later update the placeholder with a real ID and object by turning on or loading the monitor server. The MOS Gateway will then return data back to iNEWS and MediaCentral UX in the production cue.
