Copying Stories
You can copy stories from one location in a queue to another or from one queue to a second queue, including different queues within an iNEWS Community configuration. If you run a search of iNEWS stories, you can copy stories from the search results to an open queue.
To copy a story from one location to another, do one of the following:
Select the story you want to copy and press the Ctrl key as you drag it to another location in the queue.
Open two queues in separate tabs, then select the story you want to copy from the first queue and drag it to the second tab and another location in the second queue.
If you press Shift while dragging the story, the story is moved from one queue to another without making a copy.
Select a story from the search results in the Search pane, and drag it to another location in an open queue.
A copied story appears in the new place in the queue or in a new queue.
If you copy a story from one queue to another, and the preferences were set in your iNEWS client or configuration to provide a confirmation of the action, MediaCentral UX displays a message asking you to confirm the copy operation. Click OK to complete the copy or Cancel to leave the queue unmodified. For more information, see “Setting Confirmation Preferences” in the Avid iNEWS User’s Guide.
