MediaCentral | UX User’s Guide : Working with Group Clips : Adding an Active Angle of a Group Clip to an Advanced Sequence
Complete editing support for group clips is available only in basic sequences. However, you can now add the active angle of a group clip to an advanced sequence. The result is that the original master clip is used in the sequence, along with its original audio tracks.
The result is similar to using the Match Frame feature with a group clip, and then editing the resulting master clip into the sequence.
*All association with the group clip is lost when you add an angle to an advanced sequence. If you need this metadata, you must use a basic sequence.
To add an active angle of a group clip to an advanced sequence:
1. Load a group clip into the Media pane.
2. Select the active angle.
3. (Optional) Mark In and Out points.
4. Drag the clip to the Sequence Timeline of an advanced sequence.
5. (Optional) Change the audio mapping by right-clicking the clip in the timeline, selecting Audio mapping 1 or Audio mapping 2, then selecting the desired audio track.
The default track is based on the Interplay Production settings. For more information, see Configuring Settings in the Interplay | Production Administrator.
