MediaCentral | UX User’s Guide : Working with Video Media : Saving a Frame as an Image
From the Media pane, you can select a frame of video and save it as an image in either the PNG or JPG format.
• If a clip is associated with multiple resolutions, the image is saved in the highest resolution that is available on line.
• (Version 2.5 and later) If a clip uses an interlaced format (such as NTSC or PAL SD) the image is saved in a de-interlaced format to remove possible artifacts.
To save a frame as an image:
1. Open a video asset in the Media pane.
2. Navigate to the frame of video you want to save.
3. Click the Pane Menu button and select Save As Image.
4. When the dialog box appears, select the image format: PNG or JPG.
5. (Optional) Click in the Filename text field to change default name of the image.
6. Click Download.
The image is saved to the default download folder on your computer, as specified by your browser.
