MediaCentral | UX User’s Guide : Working with the File Info Pane (Interplay | MAM) : Editing the Properties of an Essence Package
The File Info pane lets you see all essence packages of the asset currently open in the pane. For the essence package selected in the Essence Packages area, you can show and edit properties in the Essence Package Details area; by default the Essence Package Details area is collapsed. In the File Info pane, if a property is editable, a text box, drop-down menu, or other input control is displayed. Your ability to edit essence package properties depends on Interplay MAM user privileges and rules.
To edit essence package properties:
1. Open the asset for which you want to edit essence package properties in the File Info pane.
2. Select the essence package in the Essence Packages area.
3. Click the Expand button of the Essence Package Details area to display the details of the selected essence package.
4. Do one of the following:
*Click in the Name field and type the new name.
Name is a mandatory field and cannot be empty.
*Click the Classification list and double-click the desired value or check its check box.
Classification is a mandatory field and cannot be empty.
*Select the Representative check box.
Since an asset can have only one representative essence package, if you select this check box, you automatically remove the representative flag from another essence package when you save your changes.
*Click in the SOC field, enter the desired value for the start timecode by typing the first digit, and continue typing until you have typed 8 digits.
*Click in the EOC field, enter the desired value for the end timecode by typing the first digit, and continue typing until you have typed 8 digits.
To save changed properties:
*Click the Save button.
The save status message changes from “Unsaved changes” to “All changes are saved.”
If you have unsaved changes and select another essence package, load another asset, or close the File Info pane, you are prompted to save the changes.
