Switching Between Associated Assets
You can use the Associations pane to switch between the source asset and an associated asset directly within the Associations pane. Pinning the source asset has no effect on whether it is replaced by the associated asset.
If the asset is included in a hierarchical association, you can directly open the parent asset in the Associations pane. The Parent button is enabled only if the asset open in the pane has one parent asset. If the asset has no parent or more than one parent asset, the button is disabled.
To navigate using associations:
1. Open the asset for which you want to see the associations in the Associations pane.
2. Expand the association types in the Associations List.
3. Click the linked name of the associated asset you want to open in the Associations pane.
The asset is opened and set as new source asset in the Associations pane.
4. (Optional) Click the Back button to open the previously displayed asset in the Associations pane again.
5. (Optional) Click the Parent button to navigate to the parent asset of the asset open in the pane.
The parent asset is opened and set as the new source asset in the Associations pane.
