MediaCentral | UX User’s Guide : Working with Associations (Interplay | MAM) : Opening Associated Assets in Other Panes
You can use the existing associations to directly open connected assets. As a result, you do not have to search for them again and again. Pinning the source asset has no effect on how associated assets are opened in other panes. Note that you can also open the source asset in other panes.
To open associated assets in other panes:
1. (Optional) Open all panes you want to use for the associated asset. For example, for a video asset, open the Media pane, Metadata pane, and Thumbnails pane.
2. Open the asset for which you want to see the associations in the Associations pane.
3. Expand the association types in the Associations List.
4. Double-click the header frame of the association.
The associated asset is opened in each appropriate pane that is open in MediaCentral UX. The source asset is still displayed in the Associations pane.
