Working in the Associations Pane
The Associations pane is divided into the Asset Details and Associations List areas, which are both shown at the same time.
To open the Associations pane:
Select Panes > Associations.
To close the Associations pane:
Click the X in the pane’s tab.
To open an asset in the Associations pane:
Double-click an asset in the Assets or Search pane.
You see the following:
- If the Associations pane is empty, the asset opens in the pane.
- If an asset is already open in the Associations pane and the asset is not pinned, the new asset opens in the pane.
- If an asset is already open in the Associations pane and the asset is pinned, the new asset does not open in the pane.
To show and hide associations:
Click the Expand All button to expand all association types and show all associations in the Associations List.
Click the Collapse All button to collapse all association types and hide all associations from the Associations List.
To select several associations:
Ctrl+click the associations you want to select, regardless of order or arrangement.
Click an association and then Shift+click the association that ends the series of associations you want to select.
Shift+click an association above or below the highlighted selection.
To remove the selection, click the Refresh button or collapse the association type that includes selected associations.
To navigate through the Association pane history:
Click the Back button to navigate to the previous view in the pane.
Click the Next button to navigate to the next view in the pane.
To navigate to the parent asset in the pane (hierarchical associations only)
Click the Parent button.
To refresh the displayed associations:
Click the Refresh button.
