Viewing In and Out Points for Log Entries
With a log displayed in the Logging pane, you can double-click a log entry so that the source clip is displayed in the Media viewer, with the logged In and Out points displayed. You can then check the In and Out points to make sure they are correct. You can use these logged segments to create a sequence.
This feature also applies to logs created for Interplay MAM assets.
Because Interplay Production markers do not use Out points, when you load a clip with a marker, the marker becomes an In point and MediaCentral UX adds an Out point five seconds after the In point. For restrictions, the In and Out points displayed match those set in the Logging pane.
In and Out points are not updated when you scrub through or play a clip.
