Navigating by Markers in the Log Layout
You can use the mouse or keyboard to navigate by marker through a clip or sequence. A marker selected in the timeline is also selected in the Logging pane. When you select a marker in the Logging pane, the same marker is selected in the timeline and the Media viewer displays the corresponding frame.
To navigate to the previous marker, do one of the following:
With the focus in the Logging pane, press the Up Arrow key.
With the focus in the Media pane, press Shift +Left Arrow.
To navigate to the next marker, do one of the following:
With the focus in the Logging pane, press the Down Arrow key.
With the focus in the Media pane, press Shift+Right Arrow.
In the Story layout, use Shift+Left Arrow and Shift+Right Arrow to navigate by markers.
