MediaCentral | UX User’s Guide : Logging Interplay | Production Assets and Creating Subclips : Cutting, Copying, and Pasting Text
You can use standard keyboard shortcuts to cut text or copy text to the system clipboard, or paste text from the system clipboard. This includes the ability to copy text from external sources such as documents or Web pages and to paste the text as marker notes. The text is pasted without formatting.
You can also do the reverse: copy marker text and paste it into an external source, such as Notepad. If you work on a story in the Story layout, you can copy and paste text into the Script Editor. You can also copy and paste entire markers (timecode and text). When you paste an entire marker into a document, the pasted text includes the clip name and frame rate.
To cut text:
*Select the text and press Ctrl+X.
To copy text:
*Select the text and press Ctrl+C.
To copy markers:
*Select one or more markers and press Ctrl+C. Use Shift+click to select contiguous markers, and Ctrl+click to select non-contiguous markers.
To paste text:
*Press Ctrl+V.
For a complete list of keyboard shortcuts, see Logging Pane (Interplay | Production) Shortcuts.
