MediaCentral | UX User’s Guide : Keyboard Shortcuts : Closed Captioning Pane Shortcuts
Keyboard shortcuts available when working in the Closed Captioning pane are listed in the following table.
Shortcut
Description
Focus
Ctrl+. (period) (Windows)
Command+. (Macintosh)
(In and Out mode) Creates a closed-caption segment using In and Out marks
Ctrl+Shift+. (period)
Command+Shift+. (Macintosh)
(Playhead position mode) Creates a closed caption with an In point only.
Ctrl+Alt+.(period)
(Playhead position mode) Creates an Out point for a closed caption.
Ctrl+E (Windows)
Command+E (Macintosh)
Divides a closed-caption segment into two, based on the location of the position indicator. The complete text for the segment is copied to the new segment, and you need to edit the text as desired.
