Sequence Pane Icons
The following icons are used in the Sequence pane.
Icon | Description |
| Adds a dissolve |
| Divides a segment into two segments at the position indicator. |
| Performs an Overwrite edit. |
| Performs a Replace edit. |
| Deletes the segment |
| Shows Audio pane |
| Saves the sequence |
| Extends or retracts a segment. |
| Shows or hides empty timing blocks |
