MediaCentral | UX User’s Guide : Icons : Media Pane Icons
Media Pane Icons
The following icons are used in the Media pane.
Buttons
Description
The Asset and Output buttons let you switch between a loaded asset and a loaded sequence.
Plays the asset or the story sequence. The Play button changes to a Pause button while the asset or story sequence is being played.
Plays from an In point to an Out point.
Moves the position indicator to the In point.
Marks an In point.
Marks an Out point
Moves the position indicator to the Out point.
Plays the last three seconds before the Out point.
Steps back 10 seconds.
Steps back 1 second
Steps back 1 frame
Steps forward 1 frame
Steps forward 1 second
Steps forward 10 seconds
Displays the Audio pane
Displays the voice-over controls
Displays the selected sequence to review for playback in the target resolution
Loads a master clip that contains a selected frame of a sequence or subclip (Match Frame).
Displays a group clip in single-angle view (1x1)
Displays a group clip in a 2x2 grid.
Displays a group clip in a 3x3 grid.
