MediaCentral | UX User’s Guide : Logging Interplay | MAM Assets : Navigating by Segments
You can use the mouse or keyboard to navigate by segment borders through a clip.
• When you select a segment in the Logging pane, the same segment is selected in the Media Timeline and the Media Viewer displays the segment’s start frame.
• A segment selected in the Media Timeline is also selected in the Logging pane. Note that this synchronization is not valid for strata that allow “overlapping segments.”
• If segments in a stratum contain several property fields, you can also step through the property fields.
To navigate to the previous segment, do one of the following:
*With the focus in the Logging pane, press the Up Arrow key.
*With the focus in the Media pane, press Shift+Left Arrow.
To navigate to the next segment, do one of the following:
*With the focus in the Logging pane, press the Down Arrow key.
*With the focus in the Media pane, press Shift+Right Arrow.
To navigate to the next property, do one of the following:
*With the focus in the Logging pane, press the Left or Right Arrow key.
