MediaCentral | UX User’s Guide : Logging Interplay | MAM Assets : Working with Segments : Deleting Segments
Deleting Segments
Any segment in a stratum can be deleted if logging is configured to Gaps Allowed mode. Depending on the position of the segment you want to delete, you will have different results:
• If the segment starts at the beginning of the video and has an adjacent segment, you create a gap the size of the deleted segment.
• If the segment starts at the beginning of the video and is followed by a gap, the gap is resized and starts at the first frame of the video.
• If the segment ends at the end of the video and has an adjacent segment, you create a gap the size of the deleted segment.
• If the segment ends at the end of the video and is preceded by a gap, the gap is resized and ends at the last frame of the video.
• If the segment has adjacent segments to its left and right, you create a gap between the segments.
• If the segment is preceded or followed by a gap, the corresponding gap is resized.
To delete segments:
*Select one or several segments you want to delete and do one of the following:
- Click the Pane menu and select Delete.
- Right-click a segment and select Delete.
- Press the Delete key.
