Splitting Segments
The Split Segment function, which is offered when gaps are allowed, works like it does when gaps are not allowed: it always defines the Out mark for the left segment and the In mark for the right segment.
To split within a segment:
1. Load an asset in the Logging pane and Media pane.
2. In the Logging pane, select the stratum in which you want to segment.
3. In the Media pane, select the same stratum to be displayed on the Media Timeline.
4. In the Logging pane, select the segment which you want to split.
5. Move through the segment in the Media pane to select the frame at which you want to split the segment.
6. To set the split, do one of the following in the Logging pane,:
Click the Pane menu and select Split at playhead position.
Right-click and select Split at playhead position.
Press Ctrl+E.
The segment is split into two segments. The former In mark remains the In mark of the new left segment, and the former Out mark remains the Out mark of the right segment. The frame that was selected in the Media pane is set as the In mark of the new right segment, and the frame adjacent to the left of this In mark is set as the Out mark of the new left segment.
The annotation of the original segment is copied to the newly created segment.
