Resizing Segments (Gaps Not Allowed Mode)
When editing in Gaps Not Allowed mode, you can move the In and Out mark only within the selected segment. Restriction: You cannot move the In mark of the first segment, and you cannot move the Out mark of the last segment.
To resize a segment:
1. Load an asset in the Logging pane and Media pane.
2. In the Logging pane, select the stratum in which you want to resize segments.
3. In the Media pane, select the same stratum to be displayed on the Media Timeline.
4. Select the segment to be resized.
The segment is highlighted in the Logging pane. In the Media pane the position indicator is set to the first frame of the segment.
5. Set the position indicator within the segment.
6. In the Logging pane, do one of the following:
Right-click the segment and select Set In or click the Pane Menu and select Set In.
Right-click the segment and select Set Out or click the Pane Menu and select Set Out.
The segment’s In or Out mark is moved to the current position. If you moved the In mark, the Out mark of the previous segment is also moved. If you moved the Out mark, the In mark of the next segment is also moved.
