MediaCentral | UX User’s Guide : Using the Assignments Pane : Create and Manage Assignments : Filtering Assignments
The Assignments list contains all of the assignments currently active for all users. You can use the filter menus and controls to view only the assignments in which you are interested.
Filter bar, with Search box and Search button; My Assignments button; menus for filtering with the Dates, Assigned, Resources, and Rundown menus
You can filter the Assignments list using the following controls and menus: button to filter out all assignments except those assigned to you.
• Search — you can filter the list based on text in the Title, Notes, Category, Topics, and Tags fields
• My Assignments — clicking the My Assignments button displays only those items assigned to you so you can see what tasks and stories make up your assignments
• Dates — the dates menu allows you to filter the list based on the Scheduled column (filter for items scheduled for today, tomorrow, within the current seven-day period, a specified date range, or all dates).
• Assigned — you can filter the list based on any MediaCentral UX user
• Resources — you can filter for any user role listed as a resource for assignments
• Rundowns — you can filter for any rundowns available in the Rundown menu
To filter the Assignments list:
1. Do one of the following
*Type a search term in the Search text box, and then click the Search button. Text searches find text in the Title and Notes fields of the Details area.
*Click the My Assignments button. You can view all assignments by clicking the My Assignments button again.
*Click the All Dates menu and select a date or date range. Clicking Date Range opens the date picker window where you can specify a date range.
*Click the Assigned menu and select a MediaCentral UX user.
*Click the Resources menu and select a resource role.
The Assignments list displays the relevant results of the filter operation.
