MediaCentral | UX User’s Guide : Using the Assignments Pane : Create and Manage Assignments : Cloning Assignments
Cloning Assignments
Assignments can be duplicated to make it faster to create multiple angles for an assignment.When you duplicate, or clone, an assignment, a new assignment is created that has the same information as the original assignment except the rundown. You can then modify the data associated with the assignment as needed.
The cloned assignment duplicates the following information fields from the original assignment:
• Scheduled
• Title
• Assigned
• Notes
• Category
• Topics
• Tags
• Resources
• Elements
To clone an assignment, do the following:
*Right+click an assignment in the Assignments list, and select Clone assignment.
The assignment is cloned and displays at the top of the Assignments list. The Title field is selected for editing.
