MediaCentral | UX User’s Guide : MediaCentral | UX for Android Devices : Customizing MediaCentral | UX Settings
You can modify some settings in the MediaCentral mobile application.
To modify MediaCentral UX settings on an Android device:
1. Start MediaCentral UX.
2. Tap the Action overflow button, and then select Settings.
3. Select the appropriate settings option.
The following table provides information about general settings.
General Settings
Description
Version
For display purposes only, this value shows the currently installed version of the mobile application.
Keep me signed in
Set to On if you want MediaCentral UX to keep you signed in once you first sign in to MediaCentral.
Logging
If selected, MediaCentral UX keeps logs on session activities, which you can use to troubleshoot issues.
If you tap the Action overflow button, a Send Log option appears that lets you e-mail the logs directly to Avid.
If the option is deselected (default), logging is disabled.
Logging Level
This setting determines how much information is logged if you enable logging. Options include: Verbose, Info, Warn, and Error.
Request Timeout
Options are intervals of 10, 20, or 30 seconds, 1 minute, or 2 minutes.
The following table provides information about the settings for editing.
Editing Settings
Description
Autosave Stories
If set to On, MediaCentral UX automatically saves a story if you tap the Back button while in edit mode. If set to Off, MediaCentral UX prompts with the Release Edit Lock dialog box if you tap the Back button while in edit mode. Tap Discard to discard your modifications, or tap Cancel to dismiss the dialog box. The default setting is Off.
The following table provides information about the settings for presenter mode.
Presenter Mode Settings
Description
Font Size
Options for presenter mode are 18, 22, 26, 32, and 38.
Normal Text
Normal text is the default text format of the story. Options are Black on White or White on Black.
Presenter Text
Presenter text is most often used for special instructions to presenters in scripts. Options are White on Black, Black on White, or Red on White.
Closed Captioning Text
Closed captioning is text sent to a closed caption encoder if your station uses such a device to broadcast text for the hearing-impaired. Options are White on Black, Black on White, or Green on White.
Skip Blank Stories
If set to On, presenter mode skips any stories that have no text or production cues.
To send log files to Avid:
1. Click the Action overflow button and select Send Log.
The MediaCentral Log dialog box opens, displaying your e-mail and text options.
2. Tap the icon for the app you want to use to send the log.
The app opens on your Android device.
3. Depending on the app, you can add a note or comment, and then send the log to Avid.
