Removing Groups from Groups
If you remove a group from a group, and the group is not a member of any other groups, the group is moved to the Unassigned group. You can reassign a group from the Unassigned group to another group or to the top-level group (Users). For more information, see
Understanding the Unassigned Group.
Removing a group through these actions does not delete the group from the database. You can delete a user or group from the database only through the user tree. See
Deleting Users and Groups.
To remove a group from a group by using a menu command:
1. In the user tree, click the turn-down arrow to open the group from which you want to remove the group.
2. Select the group you want to remove.
Use Ctrl+click (Windows) or Command+click (Macintosh) to select multiple groups, or Shift+click to select contiguous groups.
3. Do one of the following:
Right-click and select Remove from Group.
Click the Pane Menu button and select Remove from Group.
To remove a group from a group by using the group’s details:
1. In the user tree, double-click the group you want to remove.
2. In the Groups section of the Details pane, select the group from which you want to remove the group.
Click the x next to the group’s name.
Select the group and press the Backspace key or the Delete key.
4. Click Apply or press Ctrl+S.
To remove a group from a group by using the parent group’s details:
1. In the user tree, double-click the group from which you want to remove the group.
2. In the Members section of the Details pane, select the group you want to remove from the group.
Press the Backspace key or the Delete key.
