MediaCentral | UX Administration Guide : Administration and System Settings : Configuring Interplay | MAM : Configuring Central Index for Interplay | MAM
To use Central Index for Interplay MAM in MediaCentral UX, check and adapt the following settings in the Interplay MAM Administrator. Note that these settings have been configured during the installation of the MAM.Core.MediaCentralConnection package and should already show correct values.
To configure Central Index for Interplay MAM:
1. Check that Media | Index services are installed and configured properly in MediaCentral and that the system data index is created. For additional information, see the Avid Media | Index Configuration Guide.
2. Sign in to Interplay MAM Control Center as an administrator.
3. Start Interplay MAM Administrator from within MAM Control Center.
4. Open the System Administrator from within Interplay MAM Administrator.
5. In the Configuration tab, select the profile DataManagerWS > section CentralIndex and set the value of the key MarkForSynchronization to true, if necessary.
If you change the setting, you need to refresh the configuration of the DataMangerWS or restart the pool MAM_0900_DataManager in MAM Control Center's Service Controller.
6. Select the profile SyncCentralIndex > section Settings and set the value of the following keys to true.
- EnableDataPropagation
- EnableCBAAssignmentsPropagationOnStart (if needed)
- SendLegalListsOnStartup (if needed)
- SendThesauriOnStartup (if needed)
If you change a setting, you need to refresh the configuration of the SyncCentralIndex or restart the pool MAM_2200_SyncCentralIndex in MAM Control Center's Service Controller.
To trigger index synchronization in Interplay MAM:
1. Sign in to Interplay MAM Control Center as an administrator.
2. Start Interplay MAM Administrator from within MAM Control Center.
3. In Interplay MAM Administrator, open the Sync Service Administrator.
4. On the Monitor tab, select the option “Synchronize all objects” and click the Synchronize button.
All Interplay MAM objects are synchronized to the Central Index. Note that this can take a long time. This step is only needed once after enabling synchronization. As long as synchronization is enabled, all changes are propagated automatically to the Central Index. For more information, see the Interplay | MAM Sync Service Administrator User’s Guide.
