Checking the Bus Configuration
To use Interplay MAM in MediaCentral UX, check the configuration for the ACS Bus communication in the Interplay MAM Administrator. These settings have been configured during the installation of the MAM.Core.MediaCentralConnection package and should already display correct values.
To check the Bus configuration:
1. Sign in to Interplay MAM Control Center as an administrator.
2. Start Interplay MAM Administrator from within MAM Control Center.
3. Open the System Administrator from within Interplay MAM Administrator.
4. In the Configuration tab, select the profile Global > section Bus and check the following settings:
- HostNames: must show the name of the MCS host.
- DefaultRealm: must show the name of the system realm. The value must be the same as the System ID that can be found in the same profile > section SystemInfo > key SystemId.
5. Select the section SystemInfo and check if the key SystemId shows a valid value. Note that this ID must not be changed after it was set up.
