Configuring System Settings
The MediaCentral UX administrator needs to specify configuration information before users can use MediaCentral UX. You specify these settings in the System Settings layout, which is only available to administrators. The System Settings layout includes a Settings pane, in which you select the group of settings, and the Details pane, in which you specify the settings.
For information about these settings, see
MediaCentral System Settings.
To configure MediaCentral UX system settings:
1. Sign in to MediaCentral UX as an administrator.
2. Select System Settings from the Layout selector.
The System Settings layout opens.
3. In the Settings pane select a settings group, for example, General.
The Details pane displays the settings in that group.
4. In the Details pane, specify one or more settings, as described in the table at the end of this procedure.
5. Click Apply to save your new settings or click Revert to replace changed information with the previously saved settings.
